steering wheel install
im replacing steering wheel with a grant wheel, my question is how do you connect the wireto the plastic horn contact housing. that piece is the plastic piece right behind the steering wheel locking plate. and my plastic looks like it might be broken. does it come thru the locking plate. help.
RE: steering wheel install
I'm not sure I'm following you here but I'll try my best. with all the Grant stuff on except the steering wheel, you will just slide the connecting wire done the column with the big contact area at the bottom, and at the top of the wire there should be a connector to slide onto the contact plate, and yes it should come through the contact plate
I doubt I helped, but I gave it a shot[&o] |
