Speedo & tach
Hello all. Am restoring 67 RS numbers matching would like to install tach in dash and gauge cluster in cousel. Am going to rewire entire car. Will factory tach work in original circuit board? Who has the bes wiring harness??
American Autowire has an upgrade kit that will do the entire vehicle. It has provisions for all options. I just did a '68 convertible and it had everything there and then some. The only drawback might be is that you have to cut some of the wires to length and install the terminals. Wasn't that difficult though, with the proper tools.
For anyone else here is the website:
http://www.americanautowire.com/Amer...-482-WIRE.html
I bought mine on ebay. Different kits are different prices. Mostly in the $400-$500 range. I got mine for $429. The upgrade kits have extra wire harnesses include to either use factory or aftermarket guages and they have the newer fuse type fuseblock. Also, has the provisions for power accessories, speed sensors, computers,etc. They do make factory fit kits also. But the price jumps to around a $1,000. They have a real good tech advice dept. From others that I have talked to, they all like this better than Painless Wiring... hope this helps, George
