RUST
Old May 6, 2007 | 01:00 PM
mow_pro's Avatar
Default RUST
So I am starting to restore my 69. It did not look like there was a lot of rust. HA.... It really is not that bad for a car that is almost 40 years old and has never been restored. My question for the pros on this site is. What do you do about rust around the windshield channel? I have a few small rust holes in the front window and the rear window. To me it does not seem like I should replace the whole roof for a few small holes.
Any input would be greatly appreciated!!!
Thanks,
Ryan
Old May 6, 2007 | 02:03 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: RUST
I am replacing the whole thing. 1. I can afford it. 2. I know it will be done and I wont have to worry about rust living under bondo or fiberglass or whatever the shop decides to put there. I am going to try to do it myself to keep the cost down. The other way is to sand it down, get some bondo and go that route. The places you escribed are typical, I would be surprised to find rust everywhere else though. How do the pans look, trunk?
Old May 6, 2007 | 06:54 PM
mow_pro's Avatar
Default RE: RUST
I have the whole car apart. All the rust that I was waiting to find never seemed to show up. The trunk pan is like new. It still has the original paint and not a spot of rust. I do need floor pans though but I was aware of that before I started. The frame and sub frame are straight and clean. I am just worried about the rust that I talked about earlier. I have all the time in the world but would like to get going. If anyone else has any suggestions on what to do to fix the fust behind the glass fire away.
Thanks
Old May 7, 2007 | 08:38 AM
Blade's Avatar
June 2007 ROTM
Default RE: RUST
What window channel are u referring to?
Old May 7, 2007 | 06:49 PM
mow_pro's Avatar
Default RE: RUST
I am talking about the front and rear channels. Any suggestions?
Old May 8, 2007 | 05:47 AM
1969 SS's Avatar
Default RE: RUST
ORIGINAL: cplthomas
I hate to even suggest this but if you're going to fix it without doing it 100% correct (replace the panel), use Marglass instead of Bondo or fiberglass
LessThanDrew
May 2, 2009 07:12 PM
hurley870
Dec 3, 2008 02:53 PM
Jackpot4
Apr 16, 2008 08:34 PM
snake10556
Jan 14, 2008 06:48 PM
The Corvette Doctor
Nov 20, 2007 12:23 PM
