refueling
68 camaro
anybody has had a problem with hard refueling? it just seems like when i refuel, it seems to be too fast. i have to turn the nozzle a certain way and squeeze half the nozzle or it would overflow out the neck.
I would check the rubber filler hose and make sure it's not partially collapsed. If you don't have a vented gas cap, or if it went without a vented cap at one time, I could see it easily collapsing the filler hose. I believe there is a rubber cover over the filler hose held on with a couple quarter inch screws.
That's about all I can think of buddy. Let us know what you find when you take the hose cover off.
Sorry, I have a fuel cell.
cool, i thought the filler neck was metal with a rubber sleeve....i'll do what you said and see...thanks for the info.
the fuel neck is a metal tube that connects to the tank with a rubber hose. there is a thin rubber hose over the metal one then the plate that protects it in the trunk is over that. I sometimes have to watch it as well when i pump. the problem pumps are the ones with the rubber cover over them. they seem to pump faster than one without it.
its probably not the Camaros problem its todays pumps. do the pumps you use have that hard rubber fume shield? they will kick back at the slightest bit of back pressure. my 68 is a pain to fuel as well as my pickup because of the actual nozzle and pump not the car
yeah, it does....usually it would just stop the pump from pumping, but instead, it leaks out of the filler neck. so in order for me to keep fuel from spilling out, i have to turn the nozzle certain way and squeeze about 1/4 of the way making refueling a pain in the back. i guess my next mod is probably gonna have to be a fuel cell....
no it leaks right at the opening....just seems like the fuel is coming way too fast or the fuel isnt going down the tank fast enough. usually when that happens on other cars, it would just click off as if it was full, but in this case, it doesnt. is it possible its not venting the pressure from the tank and causing the fuel to back up? is there anything in the tank to release pressure besides the cap?
