-   67-69 General (https://camaroforums.com/forum/67-69-general-43/)
-   -   rear spoiler for my 68 (https://camaroforums.com/forum/67-69-general-43/rear-spoiler-my-68-a-71411/)
mikes68 Aug 28, 2012 09:14 PM
just got my spoiler in today will be putting it on this weekend any tips it came with a template so it should go smooth lol
camaroboy68ss Aug 28, 2012 09:54 PM
are you going to relocate the camaro badge like the factory?
mikes68 Aug 29, 2012 04:36 AM
didn't even think about that where is the correct place for the emblem with spoiler and thanks
1971BB427 Aug 29, 2012 11:26 AM
Don't forget to put some sealer around the holes once you test fit it, and are ready to permanently bolt it down. I like non hardening duct seal putty.
Camaro 69 Aug 29, 2012 12:47 PM
The trunk lid that's designed to be used with a spoiler has pre-drilled holes, and larger access holes on the under side. Drill your stud size holes first, then you'll need to drill a larger hole from the back side to fit the nut with a socket through. You'll be bolting up inside a cavity where the reinforcements are, the studs on the spoiler aren't long enough to go through both layers of the lid. It'll make more sense once you start drilling and scoping it out.
dynarider33 Aug 30, 2012 09:04 AM
If your car was equipped with RPO D-80 (factory installed rear spoiler) then the trunk emblem was moved up higher on the deck lid. If your car was not RPO D-80 and the dealer installed the spoiler, the dealer removed the emblem and it was not reinstalled.
mikes68 Aug 30, 2012 08:12 PM
my car never had a spoiler
