Radiator core support
Hello all
I have a 68 350 and I want to remove the radiator core support plate for cleaning and painting. Need to change body mounts so I lifted the body but still blocked under the fenders. Do I have to remove the inner fender wheel wels or at least one? Thank you for your help. Eric |
You may have to unbolt fenders and header panel from fenders in order to 'spread' fenders for r/support release.
I unbolted most of the Bolts holding the fender bit still rock solid. Only bolt left is the one on the firewall and this one is stuck. Worked only on left fender.
Wondering is scrapping off the remains of the rubber on the bottom of the support would not allow the support to go down a bit and be removable?? |
Well I got it !
I removed the remains of the radiator mounts and a couple more bolts holding the fender and I managed to take it off. Thank you |
| All times are GMT -5. The time now is 09:21 AM. |
