Radiator core support
Old Sep 26, 2020 | 06:16 AM
Eric Sabatier's Avatar
Default Radiator core support
Hello all
I have a 68 350 and I want to remove the radiator core support plate for cleaning and painting.
Need to change body mounts so I lifted the body but still blocked under the fenders.
Do I have to remove the inner fender wheel wels or at least one?
Thank you for your help.
Eric
Old Sep 26, 2020 | 02:36 PM
Everett#2390's Avatar
You may have to unbolt fenders and header panel from fenders in order to 'spread' fenders for r/support release.
Old Sep 27, 2020 | 04:26 AM
I unbolted most of the Bolts holding the fender bit still rock solid. Only bolt left is the one on the firewall and this one is stuck. Worked only on left fender.
Wondering is scrapping off the remains of the rubber on the bottom of the support would not allow the support to go down a bit and be removable??
Old Sep 27, 2020 | 04:28 AM
Old Sep 29, 2020 | 05:54 AM
Well I got it !
I removed the remains of the radiator mounts and a couple more bolts holding the fender and I managed to take it off.
Thank you
17 Again
Aug 28, 2019 04:41 PM
Chia219
Sep 19, 2012 01:59 PM
Apache68
Jul 20, 2010 02:48 PM
nacx
May 30, 2007 09:17 PM
losboricua
Mar 9, 2007 03:53 AM
