Question about 69 Camaro I just bought...
I need help to identify this motor to see if it is a true Camaro motor in my car. My car is a 1969 SS Camaro.
Casting Number: 3932386 Date Code: K308 ID Block: V1203HV The Heads: 3932441 with K98 on it Intake: 3927184 Not sure what the HV in the Block ID number is. Can you help with me with this. Thank you so much, Bill |
According to this HV is out of a 1965 corvette. It is a 350HP 327 CI motor. At least its a high performance motor.
http://www.73-87.com/chevy_ids/scode6.htm |
thanks
Originally Posted by dynarider33
(Post 459773)
Casting number is a generic number used on many engines. Most small block engines all have the same bore except 307. The stroke gives a small block its displacement. The one that counts is the 2 digit letter code at the end of the ID. That is car and displacement specific. While casting may say 69 Camaro 302 z/28, unless the 2 digit letter code says DZ its not out of a z/28.
thanks
(Post 459832)
and if it were a dz from 69 i think it would have 186 heads not 441`s
i have a 69 386 block that was a 350 4 bolt main from a 69 truck like they said its a generic number and the vin stamp on front gives the details |
Here's what you have:
3932386 block casting is a 1969 only number, used for the 302, 327, or 350. The date code K308 = November 30, 1968. The HV suffix code was used in 1965 and 1969. But since the block is a 69, that means it was originally in a 1969 Impala, RPO LM1, 255 h.p., 4 barrel, and came attached to a T350 trans. Intake manifold 3927184 is a 1969 4 bbl., used on 350 engine 255 or 300 h.p. applications. Heads 3932441 are a 1969-70 model 350, 1.94" intake and 1.5" exhaust valves, 76 cc combustion chamber. K98 date = November 9, 1968. All the engine numbers are correct for a 1969 model car, it just wasn't a Camaro engine. |
Also a 69 SS would have an L48 300HP 350.
thanks
(Post 459980)
(Post 459989)
