Popping backfire in header
I have a 69 350 with a Mallory multi-spark ignition system (i know i should change to MSD), Holley four barrel, hedman headers, and a thrush turbo exhaust. Everything was running fine until the humidity came back to Texas and know I get a pop from the right side header every couple minutes at idle and on deceleration. I checked the distributor and no signs of two cylinders firing at same time and there doesnt seem to be an arc issue with wires. Ideas???
As always, thanks in advance!
