Need advice on alternator bracket.
Small block, short water pump with power steering. I installed a tunnell ram intake but there is no boss for the alternator bracket. There is no holes in the heads. I cant seem to find any setup that will allow for a alternator. Any suggestions?
Thanks |
You're talking about the upper bracket I take it. You can connect to the upper water pump mounting bolt, with a bracket like this:
http://www.pbase.com/image/43130268 |
Sixty-six and earlier SBC's used the long bracket from the w/pump bolt.
W/pump bolt is a double studded bolt. |
I cant see the image, it just has a red x. Also the bracket has 1 bolt that goes in the water pump and 1 that goes in the intake which my intake doesnt have.
you can drill and tap the head for the threads. just find a head with holes to measure so it goes in the right spot
I think I might have found the solution
Small Block Chevy SWP Low Mount 211R Alternator Bracket | eBay |
Here's what I've used on numerous builds. It's less than $15 for the two pieces at Summit, and works with long or short water pumps. Chrome too! Works with headers or stock exhaust manifolds on the front exhaust port bolts.
http://www.summitracing.com/parts/sum-g4050/overview/ http://www.summitracing.com/parts/sum-g4051/overview/ |
(Post 684710)
I presume you already have the alternator hanging on a lower bracket, which is what those two ^ are. This is the upper bracket that was in the picture you couldn't view: http://www.summitracing.com/parts/spe-42263/overview/
(Post 684713)
| All times are GMT -5. The time now is 04:29 AM. |
