Need advice on alternator bracket.
Small block, short water pump with power steering. I installed a tunnell ram intake but there is no boss for the alternator bracket. There is no holes in the heads. I cant seem to find any setup that will allow for a alternator. Any suggestions?
Thanks
Thanks
I think I might have found the solution
Small Block Chevy SWP Low Mount 211R Alternator Bracket | eBay
Here's what I've used on numerous builds. It's less than $15 for the two pieces at Summit, and works with long or short water pumps. Chrome too! Works with headers or stock exhaust manifolds on the front exhaust port bolts.
http://www.summitracing.com/parts/sum-g4050/overview/
http://www.summitracing.com/parts/sum-g4051/overview/
I presume you already have the alternator hanging on a lower bracket, which is what those two ^ are. This is the upper bracket that was in the picture you couldn't view: http://www.summitracing.com/parts/spe-42263/overview/
