my 67 day one,
It sounds like you're describing that the lock cylinder is missing and you're trying to activate the lock mechanically. If that is the case, you should be able to use a flat bladed screwdriver by inserting the blade into the rectangle slot in the latch for cylinder link and turning it like you would the key.
musaic_design
03-11-2018 09:40 PM
musaic_design
03-11-2018 09:18 PM
