lower windshield clips
I assume you are talking about the trim clips. Unless you replaced the upper cowl panel metal the holes should still be there. In the other case use your cowl panel as a guide to get the trim in place, spread the clips out evenly and drill the holes. Exact placement of the clips does not matter.
1967, 67, 68, camaro, clip, clips, gen, illustration, install, installation, location, lower, placement, trim, windshield
