How could this happen
Old Jun 14, 2013 | 01:23 PM
69s gota get constipated so them fords quit popin out. lol.
Old Jun 14, 2013 | 02:40 PM
You still have the mono springs in the rear? Ever feel and wheel hop? I could see the rear shifting if you hit a nasty pot hole with all the weight shifted to the other side. I can not imagine the rear shifting that much with the multi leaf setup.
If you look at the stock size tires GM offered they had a fare amout of clearance between the rubber and metal.
Old Jun 15, 2013 | 10:37 AM
mikes68's Avatar
No wheel hop I have multi leaf setup I'm a little apprehensive about driving it don't want it to happen again and rippe a quarter panel should the bolt on top of the shocks in the trunk be as tight as I can get them seemed a little loose when to put a wrench on them
Old Jun 15, 2013 | 10:59 AM
check and make sure the pin that holds the differential in place is still there. i have seen one come out once.
Old Jun 15, 2013 | 11:12 AM
I don't see that as likely being from suspension movement. Otherwise I'd expect you would have crushed the lip in, not pulled it out. But by all means, inspect for any shiny spots that don't belong, to indicate any suspension sliding.
Old Jun 15, 2013 | 09:35 PM
mikes68's Avatar
well am taking her for a drive sunday I will look out for zombies and ford parts
Old Jun 16, 2013 | 05:22 PM
mikes68's Avatar
Bad news took the car out today and it happened again about a inch higher on the wheel well the leaf spring (1) and the bushings be bad
Old Jun 16, 2013 | 06:07 PM
Holy crap man, you're getting a lot of movement. Maybe the front eye on the leaf spring is broken? Had that before, but the rearend didn't walk forward like that.
Old Jun 16, 2013 | 06:35 PM
thought i seen some yellow paint on the tire. only way it could get there is if the rear moved.
Old Jun 16, 2013 | 06:38 PM
  #20
Prolly shouldn't have used those mud terrain tires too!
Tire must be catching it just right.
