Hi, I have some questions on my 1967 Camaro
Hi All,
Still new to this site.
Hopefully I can gain some good advice from you members.
I have a 1967 RS/SS Camaro.
I need help/advice in the following areas.
1) I need to know what shocks to install and the ratio's 50/50, 30/70, ?
2) Has anyone used and would recommend either the Comp Engr. Slide -A - Link Traction Bar System or the Cal Tracs Traction Bar System. Possibly someone has done a comparison on these two systems?
Although I do drive this car on the street and to the car shows I want to set it up to hook-up coming off the line, so I need advice on a Drag Racing shock package, ratio's and vendor and a traction bar set-up.
Thank you for your time and any help you can provide to me!
I'm looking forward to your advice
Po'Boy
- It currently has a 383 Stroker putting out ~ 435HP
- 350 TH tranny with a 2800 stall converter
- 12 bolt posi rear end with 3:73 gears.
- Frame connectors are installed.
Po'Boy
Last edited by Po' Boy; 11-07-2013 at 04:13 PM. Reason: update post due to color and underlin e being added
