HELP: Shorted horn relay now no power
From the factory, all the power on the drivers side comes from the wire that passes across the radiator core support and connects to the junction block, with a second wire that goes to the + side of the battery. That second wire had to have been connected to the battery for you to have power before. Make sure you're tracing the same wire before connecting it back up to the battery. How is that black wire "disconnected" anyway? Is it unbolted, snapped off, or possibly part of another fusible link that toasted and separated apart? If it's just an open wire, have you tried to find the other end? And you're sure there are no other wires on the junction block? The main supply wire from the battery should be red, unless someone did some rewiring.
Re: HELP: Shorted horn relay now no power
Ok, simple deduction...
The factory wires on the junction block are supposed to be red, now the one is black. Someone either changed a bad wire the right way, or "jury rigged" it to the battery. That second wire on the junction connects directly to the battery, with no fusible link. I only mentioned a possible fusible link on that line, knowing that someone changed the wire, but what else? Just connect that wire from the junction to the battery, and you're done. There's NO question as to where that wire goes to.
