Help with my 69 Camaro Restoration Frame MOUNTS!!!
Old Jun 3, 2009 | 10:04 PM
silverdz302's Avatar
Default Help with my 69 Camaro Restoration Frame MOUNTS!!!
Ok so I think I have gotten this figured out but I wanted some feedback. I have a 69 Camaro that came stock with a 307. I am replacing it with a 350 SBC and am currently trying to fit the engine mounts over the frame mounts. I have gone to many auto stores where everyone tells me the frame mounts are the same for the 69 307 engine and 350 engine so I should have no trouble. After buying 7 different motor mounts I found one that fit over my frame mount. After lowering the engine I am having so much difficulty lining up and need some advice. Thanks a lot!
Best, 21 year old learning as he goes...
Old Jun 4, 2009 | 12:05 PM
The 350SS (and 302 Z28) frame brackets are different from the other small block brackets. If you are buying motor mounts for a 350, then that's your problem. All small block motor mounts bolt up the same to the block, so just get motor mounts for a 307.
ATM
Jul 4, 2013 09:52 AM
clifford81
70-81 V8 Tech
Aug 12, 2012 10:01 AM
ball81
70-81 V8 Tech
Mar 20, 2010 03:20 PM
dynarider33
Nov 1, 2008 11:10 AM
ZL1innovated
Dec 5, 2006 03:16 AM
