HELP Identifying V8 engine
Old 03-21-2018, 12:51 PM
Gabet95's Avatar
Default HELP Identifying V8 engine
Good morning everyone,
I'm being offered a deal on a rebuilt ready to run 396 ci motor. The individual states the motor is the high performance 375hp version. Is there any way to verify this based on the number code stamped on the block?
The stamp reads (3902406). I would be very appreciative if anyone is able to help me confirm that the motor is indeed a factory 375hp.
TIA
Old 03-21-2018, 04:17 PM
sptrucksbyed's Avatar
What are the letters stamped on the front of the block ?
Old 03-21-2018, 10:49 PM
Gabet95's Avatar
there’s a “P” right next to the serial number. There’s also what looks like a “C1” just lower of the serial.
Are these the letter that you were referring to?
Old 03-21-2018, 10:53 PM
Gabet95's Avatar
theres also “0303 IVR” stamped on the block.
Old 03-24-2018, 07:25 PM
Y2K's Avatar
Y2K
Y2K is offline
Good info here, that would be an L78 or L79( L79 aluminum heads) motor. Should be closed chamber rectangular port heads. Originally a solid lifter cam but rebuilt most likely a modern performance hydraulic replacement.
Big Block Chevy Engine Parts casting numbers and Identification
Old 03-25-2018, 03:43 PM
Everett#2390's Avatar
From nastyz28.com:
IV 1966/65 Chevrolet 396 325 THM400
IV 1968 Chevrolet 396 325 TH
IV 1967 Chevrolet 396 325 TH with AR (smog)
Old 03-25-2018, 06:08 PM
Y2K's Avatar
Y2K
Y2K is offline
From nastyz28.com:
3902406 1967 396
325, 350, 375, 2&4 bolt
So with the IV it looks like the block at least is from a '67 325hp/396.
It could be a 2 or 4 bolt main block and could have been re-built to 375hp specs. What have you got for heads? Rectangular ports? SHP (stands for "special high performance") stamped on the inside under the valve covers?
Old 03-25-2018, 06:36 PM
Yep, pictures of numbers would be nice.
Old 03-26-2018, 07:17 AM
Gabet95's Avatar
Thanks for all the info fellas. Unfortunately the motor was sold over the weekend.
The search continues. I’ll try and get some pictures of any future opportunities.
Thanks again,
Old 03-26-2018, 11:46 AM
Al Loyrat's Avatar
My sources (Chevrolet parts manual) tell me that IV engine code is a 396 with 325HP (2 bolt mains) in 1965 through 1968 full size Chevrolets with TH400 trans without AIR. With AIR in 1967 would be code IN.
A factory aluminum head 396/375HP is an L89. The L79 is a 350HP 327 engine
Quick Reply: HELP Identifying V8 engine
