fuel gauge or sending unit?
Not sure weather the gauge is bad or sending unit can someone please help me determine by using volt meter. I tried to look for the wire coming from the sending unit but I got under the car and didn't see any. Do I have to drop the tank? Any suggestion help would be greatly appreciated.
GM fuel gauges are 90 ohms read with a meter to ground. If you open the wire with a good sending unit the gauge should go to empty. If you short the wire to the gauge to ground the gauge should go to full.
If you can't find the wire then you'll have to drop the tank. |
I was hoping I can do this hehind the fuel gauge. I thought I may be able to read the sending unit throught the 3 prong that plugs hehind the gauge. Thank you for your reply.
Originally Posted by nasty50
(Post 568678)
(Post 568403)
Are you positive? Because I just went out to the Suburban and tested this since it's got a plugin connection. If I unplug it the gauge goes to empty, and when I ground the wire from the gauge to the frame it goes to full.
Haven't tried the Camaro to see if it's the same, but I thought all GM's were this way? |
Not all cats are skinned the same: Troubleshoot Fuel Gauge
On my Camaro if the wire from the sending unit isn't hooked up my gauge goes to full
Same on my C10 |
I'm really confused now. Not sure why the Burb does the reverse, and from others I've talked to with old Suburbans their gauges work the same. Suburbans have a nice little single wire plug right at the tank, so very easy to service or check.
I appreciate all the replies but somebody scholl the nubee on how to ground it!
Also this is how my gauge look key on or off. http://img.photobucket.com/albums/v3...908_060031.jpg |
