Fender Removal?
Old Dec 6, 2007 | 11:05 PM
frostlime69's Avatar
Default Fender Removal?
I am planning to replace driver side fender due to quick repair from "fender bender" back in the 70's, and now bondo (filler)is cracking along with some rust. What would be the main hang up I should expect? Cutting, welding, shims? Thanks for the time.
Old Dec 7, 2007 | 04:48 AM
MichiganMan's Avatar
January 2008 ROTM
Default RE: Fender Removal?
ORIGINAL: frostlime69
Fitment if useing aftermarket panels can sometimes be hard to get body lines/gap's to line up.usuallya shim here or there will do the trick.Or if your chip foose place on ground for maximum leverage and tweak this and that and wallah.original gm panel'sfit much better,hard to find,hard to stomach the cost
Old Dec 7, 2007 | 06:08 AM
Blade's Avatar
June 2007 ROTM
Becareful with the shims.
Old Dec 7, 2007 | 09:48 AM
I will be going to an old car swapmeet just south of from here, and I hope I find a GMfender. If not after market is the way to go.
Old Dec 8, 2007 | 10:31 AM
jonnyNITRO's Avatar
How bad is the damage? Post a pict.
This what I had to replace.
Look at the bondo packed-in.
[IMG]local://upfiles/7269/8305D27778654CB29A125AFEA4B07388.jpg[/IMG]
[IMG]local://upfiles/7269/29A4CF295414407FAE2765894FA12BC8.jpg[/IMG]
Old Dec 8, 2007 | 10:17 PM
Hi Jonnynitro. I have'nt got it down to metal, but a magnet won't work anywherebelow the fender flare. I also see patch work just above the fender skirt. Obvious also is that the top of the fender where the windshield meets, there is about 1/4" gap, telling me that the fender was pulled down upon impact to lower portion of fender. I will post some pics soon. What format and what size do you post your pics? Your pics always turn out clean.
Old Dec 9, 2007 | 07:00 PM
jonnyNITRO's Avatar
I use a image editing program to size the image to 72 DPI(dots per inch) and a size of about 8" as a JPEG format.
Old Dec 11, 2007 | 10:09 PM
1969 SS's Avatar
is that the fender or actually the quarter panel?
Old Dec 12, 2007 | 12:12 AM
Front fender drivers side, quarters are fortunately fine. Thisis my winter project, along with a few other items.
Old Dec 12, 2007 | 07:10 PM
FlightMechYJ68's Avatar
Man, replacing a fender is easy...Get yourself some shims and line that stuff up and bolt it down and call it good. Just kidding, Getting your lines err... lined up is gonna make it the difficult art...
