fender emblems
hey guys. Painted the car now have to put the fender emblems on. its the camaro ss emblems on the fender. cant get to the inside of the fenders to put the nuts on. is there a trick to this. maybe some kind of adhersive. I think i screwed myself.
They have to be put on before you install the fender otherwise you cannot get the nuts on the back of the emblem studs. If you do not want to remove the fender you will need to use some sort of adhesive.
They make clips that fit in the holes drilled in the fender for the emblem, and then the clip will lock onto the studs on the emblem. Check your local body shop suppliers.
| All times are GMT -5. The time now is 04:57 AM. |
