69 396 fuel pump problem
Old 07-06-2018, 05:53 PM
Juniorss1386's Avatar
Default 69 396 fuel pump problem
Hey guys new to forum I have a 69 396 long story short changed tank,sending unit and mechanical fuel pump and car still won’t start runs for a second with starting fluid and making a weird sound kind of high pitch squealing I hope it’s not a defective fuel pump again
Old 07-06-2018, 07:07 PM
Al Loyrat's Avatar
Fuel pump pushrod?
Old 07-06-2018, 07:27 PM
Made sure it was up all the way guess it could have slipped down used bearing grease
Old 07-06-2018, 07:29 PM
Will try again tomorrow
Old 07-06-2018, 07:32 PM
Had to take pump apart to rotate housing inlet and feed to carb hope I didn’t mess up pump
Old 07-06-2018, 07:35 PM
Y2K's Avatar
Y2K
Y2K is offline
You might have a bad fuel line hose, they can collapse and or split when they get old and deteriorate ,could be sucking air making the noise.
Old 07-06-2018, 07:37 PM
Everett#2390's Avatar
Has the inlet hose at pump been removed and low pressure shop air applied to tank fill tube for priming the fuel line?
Yes, today's recipe kills fuel hose.
Pump is fine.
Old 07-06-2018, 07:39 PM
Y2K's Avatar
Y2K
Y2K is offline
I ran an electric pump mounted near the tank on my big block '69,after that I never had any vapor lock or fuel delivery problems even again.
Old 07-06-2018, 07:46 PM
No didnt prime fuel line gas ate tank away so I changed that will try air tank tomorrow thanks guys
Old 07-06-2018, 07:48 PM
I put about 2 gallons of fuel in after tank change
Quick Reply: 69 396 fuel pump problem
