Dead!
Old Aug 24, 2014 | 05:29 AM
coolbeverage's Avatar
Default Dead!
I was going to try to work on my timing issues yesterday. I go into the garage and turn the key to a totally dead car. Parked it in the garage last weekend and minus this timing issues everything else was fine. I HATE WIRING ISSUES! Anyone have any ideas where I should start. Clues; I put my battery charger on it and the yellow light that indicates it is in the charging process would never come on. I put a multi meter on the bat and it was reading low. Do you think I maybe lost my main ground hence the charger not working? I hope the issue isn't under the dash but my tach did oddly just stop working out of the blue 3 weeks ago. Start at main battery to block ground? Thanks fellas
Old Aug 24, 2014 | 06:36 AM
flat tire's Avatar
how old is the battery?
is your charger actually working?
is the battery terminals clean/ tight?
brake light stayed on to drain the battery?
glove box light stayed on to drain the batter?
any other accessories left on?
Old Aug 24, 2014 | 10:55 AM
If the charger is good and you connected it directly to the battery posts (in the proper polarity) and the charge light stays off, it is a good indication that the battery has gone open internally and has to be replaced. However, get the battery tested before getiing rid of it.
Old Aug 25, 2014 | 12:23 PM
old guy's Avatar
Yup, what he said!
RS camaro
Dec 3, 2010 05:57 AM
Killzer
Sep 30, 2009 11:12 PM
Jeramy
Dec 25, 2007 05:13 PM
