Curious... Engine runs horrible after 45 minutes
1969 Camaro 307 with Edelbrock 650 4bbl
So the car runs fantastic when I first fire it up. If I drive it around for about an hour it starts to diesel a little at idle and feels like it's missing half the cylinders when I hit the accelerator. I have to flutter the gas pedal or it feels like it'll get die out. Eventually it gets up to speed and runs smooth, but it sounds like hell getting there. Everything about this feels like a vacuum issue, but I've replaced all of the tubing recently and checked the seals. I'm going to keep going down that route and get a vacuum gauge but I wanted to throw it out to the community and see if anyone had any other suggestions.
One possibility is an intake manifold leak, that shows up after the engine warms up and things start to warp. And it could be on the inside (lifter valley side), where you wouldn't know it.
Have you recently replaced the intake manifold, and/or checked to see if the bolts need to be re-torqued?
Sounds like a vacuum leak,, get some starter fluid and spray the manifold and carb base when it's warm and see if it evens out. If the motor is cold and you spray it then it will bog out if it's got a leak.
Actually this was a problem before and partly the reason for replacing the hoses. The hoses that were there were old and cracked. One had a severe leak and caused the car to bog out really early in the drive. All of the hoses are new and cut to appropriate lengths to avoid pinching and crimping. All connections are secured with threaded hose clamps with the exception of the hose from the carb to the vacuum advance. I was partly joking earlier and am certain the hoses are connected in the right places.
Greatly appreciate it. I had an electrical issue last week that was due to a wire being hooked up in the wrong spot. I always appreciate people reminding me to check the basics first because I tend to overlook them and assume it's something more complicated.
