Chris's 69 resto project
Old 11-02-2007 | 02:21 PM
SS396's Avatar
Default Chris's 69 resto project
Hey all,
Looking at putting the font end partially back together this weekend. After many hours of sandblasting and painting, I'm definatly ready to see it going back together. Here are some before, during and after pics of the A-arms.
[IMG]local://upfiles/10233/BDA476880AEF41C2B759C3B33A657ECD.jpg[/IMG]
[IMG]local://upfiles/10233/036724231D61459697FA1F9F78308DB6.jpg[/IMG]
Old 11-02-2007 | 03:16 PM
Blade's Avatar
June 2007 ROTM
Default RE: Chris's 69 resto project
those are the same parts?
Old 11-02-2007 | 08:45 PM
awesometool's Avatar
Its dirty work but someone has to do it. What did you use to paint them?
Old 11-05-2007 | 11:15 AM
SS396's Avatar
Well, after a few hours worth of work, here are a few pics of the project. First pic is pre-assembly, then post. Original: frame and A-arms. New: grade 8 bolts for assembly, Hotchkis 2" lowering springs (no compression necessary for reassembly) new gas-adjust shocks, new 1" sway bar. All new graphite impregnated polyurethane bushings. Donor spindles until I spend the cash for a 4 disc brake set-up.
As for the paint, etching primer and rust-inhibitant semi-gloss black. I buy in bulk (gallon) and have my own air sprayer
Old 11-05-2007 | 11:27 AM
SS396's Avatar
Hmm, it didn't like my pics, lets try this...
http://chrisdehaan.myphotoalbum.com/
[IMG]local://upfiles/10233/DA018757E447454E8D4296A46AA8D6A6.jpg[/IMG]
Old 11-05-2007 | 09:21 PM
WULFFTRUBLE's Avatar
you looking for a bad *** set of front springs for it??
i have a set of adjustable coil overs that will bolt right on and give it up a 3 inch drop
Old 03-02-2008 | 06:26 PM
SS396's Avatar
Well,
Some update pics are well overdue. Here are a few of the finished flootpans, and the old left rear framerail and new. The new old is from Rick's first gen, and it looks like it will fit in with no banging around. It also looks like is ismade of thicker metal. More pics when I get it in.
[IMG]local://upfiles/10233/2A7A9FAF2D57498A8E6A1DCF07A70816.jpg[/IMG]
[IMG]local://upfiles/10233/B7C95C77F60443E1B7B25E7D547E205B.jpg[/IMG]
[IMG]local://upfiles/10233/35893DE04EC74AC8854E6B5A2EF6EFE0.jpg[/IMG]
[IMG]local://upfiles/10233/C538363D49084F0095B667E5D1AE42A7.jpg[/IMG]
Old 03-02-2008 | 06:27 PM
SS396's Avatar
Oh, and for those of you that have seen the poor mans rotisserie, when I work on it, I usually have to foor jacks in place
Old 03-02-2008 | 09:56 PM
FlightMechYJ68's Avatar
hahaha Yeah, I can't lift mine like that in good conscience... it'll bring the house down...literally...
Old 03-04-2008 | 01:44 PM
Ejam's Avatar
Chris do you have the original motor? If so what was it ? bb? hp? auto/stick?
Quick Reply: Chris's 69 resto project
