Budget Quick Steering Box for my '69 Camaro
11 Attachment(s)
I'm in a few forums and have posted this info elsewhere but not everyone goes to all forums. So I figured I'd post this here... maybe it'll give some inspiration to another 1st Gen Camaro owner who wants quick steering but has a budget.
Like many, I spend way too much money and time on my car, but thats what the "hobby" is all about. Still, if I can get some low-buck improvement in any aspect of my car I'm going to take a serious look at it. My car is an X44 '69 Camaro coupe... and its a restomod. One thing I wanted to do was upgrade the brakes, suspension, and steering. So the front end got power disc brakes (Wilwoods/CPP/TuffStuff), Hotchkis 2" drop coils, Helix tubular uppers and lowers, ProForged ball joints with tall uppers, ProForged tie rods, ends, and the Helwig 1-1/8" front bar is enroute as I write this. Have to give Dave Pozzi props for giving me some tips and information. And thanks to Jeff Loud [LSX69] who prodded me into doing this write-up. Jeff's going to give it a try in his car now. My car was originally a small block V8, automatic, power steering and dual exhausts. The steering was awful, seemed like 15 turns lock to lock and response was as slow as molasses. While I'm sure the steering boxes from Lee and other high-end rebuilders are without compare... I noticed that on the compatible Saginaw steering box list they had the Jeep Grand Cherokee from the mid-'90s as a decent candidate. https://cimg5.ibsrv.net/gimg/camarof...8a45721728.jpg I did some searching on CL and found a local guy who was in the process of parting out his sister's JGC that had been T-Boned on the passenger side. I called up and asked if he had a steering box and if so, what condition. He said he'd pull it out and take some pix which he sent to me. Long story short... I drove up to his house and bought it for $45. Obviously looked a little grimy, but it didn't appear to leak, and it seemed smooth when turned by hand. I set about cleaning it up last winter as one of my many projects. Got it installed a couple months now, and all I can say is "Night and Day" difference. As with all these newer Saginaw boxes, you'll need to pick up the correct rag joint and a set of adapters for the hoses. But other than that, its a direct bolt-in and you use the original power steering arm (or pick one up from Rock-Auto). Thought I'd post some pix of the restoration. Attachment 46198 Kinda dry and rusty, but solid and smooth. Started wire-brushing it because if it was going in the car it had to look decent. Attachment 46199 Wire-brushing got the box looking pretty decent as far as a used, 20 year old component was concerned. Attachment 46200 Having had done other suspension cleanups over the years, I'm a firm believer in using a good metal etching primer. Attachment 46201 I like Rustoleum's "Hammertone" paints for cast items. Did my best to clean and polish the oxidized aluminum parts, clear-coated those. Attachment 46202 These numbers may or may not be helpful in identifying a '96 JGC box, but I figured I'd include them. The "214496" is so lightly engraved it barely shows up in pictures. Attachment 46203 I did find another picture (see below) where you can barely make out the numbers on the end cap. Attachment 46204 Sorry about that LOL. Attachment 46205 So here's the rag joint you'd need to retrofit the '96 JGC steering box into your '69 Camaro. Probably all three first gen years. Believe its a Chevy S10 rag joint. Attachment 46206 Here's the Borgeson adapters, available from many online vendors. These ensure a nice, tight and so far... leak free connection using your existing PS hose. Attachment 46207 Depending on which headers you have, you might have to work the tubes as supposedly the '84 and up Saginaw boxes are 1/8" wider (I never checked). Attachment 46208 Best I can do from the bottom until I get back on a lift LOL. Last week of July I put on 1053 miles in one week, drove from Massachusetts down to the Jersey Shore for some family vacation time. Real long distance road test for my brakes, suspension, and steering mods. Happy to say nothing happened... the box is still as dry as a bone in the desert. So the bottom line is that for well under $100 my car's steering is ultra responsive and no longer wallowing all over the road. I'm sure there's plenty of people who will suggest that the only way to go is new, but so many have opted to search out '84 IROC boxes or their equivalent and been disappointed to find that they didn't get a real one made me figure why not give the JGC a shot? The IROC/Monte Carlo boxes (if you can find one) has a slightly thicker shaft, maybe a little better feel... I don't know. This started out as an experiment, and I figured if it sucked... I could always go buy a remanufactured box for a couple hundred and hope they put decent parts back in it. This box is 12 years newer LOL than an '84 IROC box so they're both ancient. It did however, turn out to be just the ticket for me. I'll probably upgrade the hoses this winter, maybe braided SS. Hope this little pictorial helps a few people. And don't forget that a wealth of information is over on Dave Pozzi's page, especially the above chart showing various alternate choices for steering boxes. Maybe if enough people like this they'll make it a sticky. Enjoy! Mike |
Hey Mike,
Great write up. Ironically, I just got done with the box swap myself and I used a 96 JGC box as well. I went from manual to PS to I had to buy a different pitman, rag joint, adapters, pump, stock brackets for pump, pulleys and belts and hoses. I got my box from a pick and pull junkyard for $50 also grabbed the pressure valve from the pump off the JGC in case the new Tuff Stuff pump I bought couldn't handle the hi pressure (which it has done fine at 1200 psi) I like the fact that the JGC box has the correct steering stops internally. I have heard some of the IROC boxes do not. Also, I found some killer adapters to convert from metric to sae if your using your stock lines. https://www.summitracing.com/parts/clp-605sol This is a great alternative to the press in adapters. After looking at your picture yours shows the box shaft protruding thru the pitman arm it looks like your nut is torqued down further than mine. I was afraid to over tighten mine because I had to use a 1 5/16" wrench on mine. I wasn't able to torque it because I couldn't get a socket on it. Stupid headers. In hindsight I should have torqued it on before installing the box. Good news is, I have headman ceramic coated headers and it cleared without any modes. Barely. Heres some pics of mine. The box when it was "new" https://drive.google.com/file/d/1eLq...ew?usp=sharing My restoration of the box using cast iron grey https://drive.google.com/file/d/0B_D...ew?usp=sharing Nicely nestled in her new home. https://drive.google.com/file/d/0B_D...ew?usp=sharing No doubt this mod is the biggest bang for your buck. I spent $600 doing the whole thing but I didn't have to get a chrome pump, aluminum pulleys, etc... I just wanted the bling too. If you have PS already on your car this is a really cheap mod. |
It IS the biggest bang for the buck... provided you find a good box lol. Which it looks like you did. My bling will come a little bit at a time. I have my Vintage Air kit and I spec'd the DS compressor, maybe thats a mistake, I don't know. I can't afford a March Serpentine system that costs more than the VA system, so for now it seemed simpler to go with one new bracket. But I did get chrome pulleys. Pretty soon I'll start tearing into it. Loosening the fender and liner to get at the heater box stuff is my biggest fear... worried about the paint. Will invest in lots of wide blue tape.
I'm using the PS pump I had... I have no idea if its an original or replacement, its been on the car at least 10 years. Surprising that there's no pressure issues. May someday get a TuffStuff pump... I have their dual diaphragm booster, and love it. |
My car came with VA so I don't have to go down that road. However, it has a leak and I can't bring myself to get it fixed. Maybe someday, but Id rather cruise with the windows down! :-D
