Best place to sell matching # 68 z 28 project
how much of a project is it?? is it stripped to a shell with all parts?
is it a complete car rolling? is it all numbers matching engine,trans,rear???? more info would help??
is it painted ?is it rusted (needs quarters etc??)
100% rust free Ca car matching engine, not trans, rear has had weld on traction bars so #s are gone but the date is correct. Body has been put into K36 primer all original GM panels the car came with. Floors perfect, trunk perfect, rockers perfect, and a real GM cowl hood. The engine is not in the car and it has been torn down to rebuild. Had the crank turned, block is 40 over and ready to go, heads need rebuilt, have all correct pulleys, brackets, intake, carb, intake, air cleaner, pan, valve covers, not matching # dist. The car was built in late 67 and I think the 453 camaro built in 68
i am sure you know you would get the most for it completed!!
now if you want to sell it i would try here
www.teamcamaro.com
or
http://www.carsonline-ads.com/colsit...e&cmd=showHome
www.teamcamaro.com
or
At least list it as having a matching numbers engine.
I once went to a collector car auction and there was an old Vette on the block. Auctioneer yelled out "All Numbers Matching Car", then in a little lower tone "except the block". Gee, that's kinda an important missing part to still call the car numbers matching. I was ready to jump out and choke the sh** out of him.
