Bad bearing- water pump or alternator?
Old Feb 28, 2013 | 08:00 AM
  #21
bruce69camaro's Avatar
I think that is a smart move. Not worth taking the chance. There will always be more shows.
It happened to me one time with a blower motor I had and it scared me big time.
I noticed a puddle on the ground and checked things out and saw the pump was leaking but I had to get it home.
I watch the temp gauge more then I did the road. Luckily I wasn't too far from home and I got it back safely.
Old Feb 28, 2013 | 09:44 AM
  #22
If it was into town and back, I wouldn't let it worry me so much (unless it takes those 15 miles to get into town). You could always do the run it for a short bit, let it cool down, add more coolant, then run it again technique. Been there with that one. A leak is only going to get worse. It could start a waterfall next month, next year, or within a mile of driving.
Old Mar 2, 2013 | 10:06 AM
  #23
Chrisd0729's Avatar
Is a stock 69 v8 water pump what I ask for at the parts place? Looks like napa has a tru flow for only $28
Old Mar 2, 2013 | 10:37 AM
  #24
Chrisd0729's Avatar
I looked up on autozone and napa and the waterpump for 68 and 69 v8 doesn't have the heater core outlet on the top. Should I be looking for something different?
Old Mar 2, 2013 | 11:27 AM
  #25
On the Napa site, look at the rear view of the pump. You can see the angled hole at the top above the rear plate.
You either reuse your existing fitting, or buy a new one. Don't forget to use a thread sealer (not RTV/silicone).
Do not ask for a pump for a 68, it will be the wrong one. Get one for a 69.
Old Mar 2, 2013 | 08:43 PM
  #26
Chrisd0729's Avatar
Ahhhhh... I see it now. Just ordered that one.
Thx again
Old Mar 10, 2013 | 09:15 AM
  #27
Chrisd0729's Avatar
Should the heater core hose fitting in the intake manifold also be 3/8 npt like the water pump?
Thanks
thebandit110
70-81 V8 Tech
Feb 27, 2013 12:43 AM
doww301
Apr 4, 2011 02:49 PM
gville4life
Feb 26, 2010 10:00 AM
Camaro 69
Jul 6, 2009 01:41 PM
1995z28AJ
Jul 22, 2007 11:40 PM
