--Anti-Theft Device--
..thinking bout putting some kind of hidden switch installed on my car..I'm sure alot of you fellows have some kind of device, homemade or bought and I'm certainly NOT asking you where it is
..but hoping you could recommend something..Thanks
![Icon Slap2](https://camaroforums.com/forum/images/smilies/icon_slap2.gif)
What year? Would you like this thread moved to a more pertinent spot, like a generation specific area? Don't know why you want it in drivetrain tech.
For starters, make sure you have a secure door locking system. This one isn't very good.....the chain is too thin and cheap.
![Name: car-lock.jpg
Size: 31.6 KB](https://camaroforums.com/forum/attachments/67-69-general-43/15938d1501211918-anti-theft-device-car-lock.jpg)
![](http://i157.photobucket.com/albums/t58/CamaroChuck/car-lock.jpg)
![Stick Out Tongue](https://camaroforums.com/forum/images/smilies/tongue.gif)
By the way the years not pertinent
![Icon Really](https://camaroforums.com/forum/images/smilies/icon_really.gif)
One good place would be out in plain sight. Put two or three switches on a panel and wire them in series to where they have to be a certain combination of up & down (not all the same position) to be live. Car thieves are pretty smart about looking for, and finding hidden kill switches. Honestly though, no kill switch could stop me if I wanted your car. A jumper wire from the battery to the coil powers the ignition, and a screwdriver to jump across the starter terminals is all it takes to drive away. Gone in 30 seconds! I'd look into getting a hood lock and a battery quick disconnect if you plan to ever leave your car sit out for a while without keeping an eye on it.
Moved this thread to the 1st Gen general section.
Look under the dash edge, you will see mounting holes for the power top switch.
Make an right angle bracket for a 15-20 amp SPST toggle switch
Mount switch to bracket, mount bracket on the inside of dash edge - hides the switch - and place the handle outwards, towards the pedals.
Run ignition power through the switch.
If you want to kill the car, mount a battery switch on the pass fenderwell with the key side on the tire side - insert red handle to lock/unlock power.
Take high tension coil wire with you when you leave the car.
If you don't have a lock for your hood, a hidden kill switch (easy enough for thieves to find) is a waste of time, and will give you a false sense of security. Walk up to your car, pop the hood, take a pre-made length of wire with alligator clips on each end and connect the coil to the battery, reach down to the starter with a screwdriver and start the engine and drive away. Yes, it's that easy and fast to rip off your car. If I were a car thief, I wouldn't even waste my time looking for a kill switch, or bother messing with hot-wiring the ignition switch, it can all be done under the hood. A removable steering wheel on the other hand, locked in the trunk, is a better deterrent.
As far as hood locks go, some choices are hood pin style key locks, or a dead bolt security lock, both of which require drilling holes in places you may not want to. Or a chain lock attached to the hood latch and dropped down to the frame crossbar.
