AC compressor lt1
Old May 9, 2015 | 09:14 AM
plozier's Avatar
Default AC compressor lt1
I have an lt1 motor in a 69 z28 and now want to add AC. Is there any body out there that has done this? Compressor mounting has so far, not been very optimistic. Corvette brackets? aftermarket? HELP!
Old May 9, 2015 | 09:15 PM
what kind of belt system do you have?
Old May 10, 2015 | 06:56 AM
plozier's Avatar
Engine, tranny, computer, drive system, ect. came from 94 roadmaster. Serpentine belt is short answer.
Old May 10, 2015 | 10:29 AM
moved your thread to the first generation general section. hoping one of the guys here has some ideas for you. so ac mount from road master won't work?
Old May 11, 2015 | 06:12 AM
plozier's Avatar
The A-arm on right side limits the amount of space where compressor is intended to be with that bracket system. Do you have any suggestions for getting this issue in front of more people? I am betting there is some body out there that has solved this it.
Last edited by plozier; May 11, 2015 at 06:18 AM. Reason: More thoughts came after hitting the go key
Old May 12, 2015 | 09:01 PM
clinebarger's Avatar
Been awhile since I installed a LT1 in a 1st Gen F-body/2nd Gen X-body, IIRC You can just notch & plate the crossmember & compressor will fit....But the hoses are still a PITA.
92-96 C4 Vette brackets are you best choice, Just make sure to get EVERYTHING, There are a lot of parts to a Vette accessory drive.
March Performance has a accessory drive kit March Performance Chevy LT-1 Style Track, Expensive for what it is, Have to run "Speed Density" or run an ugly adaptor for the mass air flow.
Stay away from Street & Performance brackets, They are junk.
Old May 12, 2015 | 09:54 PM
plozier's Avatar
Yes the cross member, not the A-arm. Any possibility of moving the motor enough to accommodate the compressor? Any recollection of the amount of trim on the cross member? March Performance system about $2000
Old May 12, 2015 | 10:25 PM
Back to the engine perch for F-body LTI accessories, B-body accessories space a little farther forward.
I do not know actual dimensions, Not that I ever kept track.
Moving the engine forward effects handling & weight transfer, Not a good idea.
Keep in mind the rear of the compressor needs a brace, And needs to be modified to work with your stock engine mount. Do you have the stock B-body compressor brace?
Old May 13, 2015 | 08:22 PM
plozier's Avatar
At the time of the robbery of the other car I had no intention of AC, now the car is gone,although there are some other guys in the area that have kept parts better than I have. I think I am going to succeed getting compressor ect. from one of them. Where do you call home?
Old May 13, 2015 | 09:57 PM
Fort Worth, Texas
