69 z28 engine decoding help
Old Jan 8, 2008 | 10:41 PM
michael A's Avatar
Default 69 z28 engine decoding help
I'm trying to see if my engine is the correct engine for my car. the block has a casting number 3970010. the casting date is M47 which does't add up. the vin is stamped by the oil filter housing where it should be and looks very professional done. the block has been dected to where there is no numbers on the front pad. I was about to give up when i found some information on M date codes. www.camaros.org theres a paragraph on M coded blocks. the way i read it there is no way to determine the date on M coded blocks. Just woundering if anyone has run into this before? Im going to try the acidetching to see if i can bring some numbers back. Doe's anyone have any input on this? Thanks mike
Old Jan 8, 2008 | 11:57 PM
Default RE: 69 z28 engine decoding help
True, the M can't be a date code since the date codes are A-L (January-December). Even though the write up says you shouldn't have a date code, out of curiousity did you look to see if there was a date code at the bellhousing on the passenger side of the block?
Old Jan 9, 2008 | 11:22 AM
Ircyklops's Avatar
I would say that, if you have a 3970010 block AND you have the correct VIN stamped by the oil filter, then thatshould be proof enough that you have the original engine to that car. (As long as the VIN looks authentic). Consider yourself lucky that you may have one of the few smallblocks that actually have a VIN by the oil filter. As you know, most were on the front pad and were often removed by decking.
Here are some more sites to check out...
http://www.chevy-camaro.com/chevy-ca...gine-codes.asp
http://www.68rscamaro.com/69cams/
http://www.blake.com/oemcarbs/chevy1.htm
Old Jan 9, 2008 | 09:22 PM
michael A's Avatar
Yes the block casting date reads M47. which the 0010 block wastn't casted untill the year of 69. But this block looks like a older block by the different structure on the sides of the lifter valley. also the front pad where they stamp the block is big like the older blocks were. I know the later 70's they change the size of the front pad. so you think if this block was a 1977 block it wouldn't have any of these features.
sraey8
Mar 15, 2026 12:28 AM
Camaro 69
Jul 29, 2012 11:24 PM
PA68
Feb 6, 2011 06:52 PM
racersdad04
Dec 23, 2008 09:02 AM
Dman
Nov 9, 2007 02:09 PM
