68 Z28 Intake and Carb
Original Intake and carb off a 68 Z28. Then have been sitting in dry storage for the last 20 years. What are they worth? A friend of mine is building a Chevelle and was going to use these because he had them. I told him to hold off till we know what they are worth.
I should have all the numbers in a day or two. |
so its the aluminum high rise? they can worth quite a bit, i dont know what they are going for right now i havent seen any go across ebay in a while
He called me with the numbers, The Carb is just an older after market. The intake is a 68 Z28, I don't think it is a high rise. A quick search of ebay showed piced from $400-600.
GM 3917610 |
it should have a taller rise on it when compared to a stock iron manifold. Also the numbers are right for a 68 z28 intake.just asking probably obvious questions does it have the winter snowflake on it? is there any bowtie on one of the rear runners? if it has the bowtie then it is a GM over the counter piece. they are identical to the z28 intake but they were just sold over the counter. I have one on my 68
He said it had a "W" on it. The guy said he took it off his Z28 in 76 after he blew the motor.
well did the w look like this?
http://t3.gstatic.com/images?q=tbn:A...gRCoIPhR6Q&t=1 if it has this then it is a true chevy piece all aluminum factory intakes had this on them as well as the ZL-1 blocks |
I got some pics and more information. I no long believe it is a 68 intake. I think it is an original intake off a 67. That would make it one of 602 made. I will add pics tonight.
