68 camaro
Hi my dad is rebuilding a 68 camaro ss
and it used to have a 350 in it with a manual and he is putting a 454 in it with a automatic trans and we are putting the 454 in and we are trying to use the old 350 transmission bracket and it isn't working the bracket it is not low enough for the trans to fit between it and the housing what should we do? will we have to buy a trans brace for a 454 automatic trans? thanks |
RE: 68 camaro
ORIGINAL: isaac11 Hi my dad is rebuilding a 68 camaro ss and it used to have a 350 in it with a manual and he is putting a 454 in it with a automatic trans and we are putting the 454 in and we are trying to use the old 350 transmission bracket and it isn't working the bracket it is not low enough for the trans to fit between it and the housing what should we do? will we have to buy a trans brace for a 454 automatic trans? thanks Did you change the motor mount frame brackets too? They are different between small and big block applications. Is your clearance problem between the trans and the tunnel? If so, it's because the engine is sitting too high with the small block engine mounts (if that's what you still have). For reference, years ago I converted a different 69 Camaro from automatic to 4 speed, and the same trans crossmember worked just fine. |
RE: 68 camaro
thanks
we have new motor mounts for the 454 yes that is the problem it is too tight between the transmission bracket and the tunnel |
RE: 68 camaro
Something I didn't ask, what auto trans are you putting in? With your clearance problem, I'm gonna guess it's a T400? The 400 uses adifferent crossmember than the T350and manual trans does.
RE: 68 camaro
im not exactly sure
see the engine was built too test torque converters and the trans was also bulit too go with it it says j7 on it and all i know is it is a 3 speed |
RE: 68 camaro
Knowing what trans you have is kinda important. The shape of the pan will tell what you have. Take a look at yours, then look here:
Chevy Auto Trans ID |
RE: 68 camaro
thanks I will look at it tommrorow
RE: 68 camaro
alright so we figured out a trans is a th350 or a th375b
so and we can't find motor mounts for a 454 just for like the small blocks and do we also need to interchange the engine frame brackets because we have the small block frame brackets and the motor mounts we have we went to oirellys and the said these are 454 motor mounts but the trans is too tight between it and the old cross member ? |
| All times are GMT -5. The time now is 07:32 AM. |
