67 rs relay electrical problem?
Old Feb 22, 2012 | 08:37 PM
freddybush's Avatar
Default 67 rs relay electrical problem?
Can anyone help me, with all switches off and battery disconnected when battery reconnected should the headlight relays click?
Old Jan 7, 2025 | 01:58 PM
billybob's Avatar
Unhappy Relays clicking with all switches off
I have that same problem with my 1967 rs, with ignition and headlight switch off, as soon as i connect battery the relays, and circuit breaker click every 15 seconds and i get a spark off the breaker , so i discoonect Battery quickly. If i start the car the clicking and spark goes away?
Seems like the system is getting charged before i turn anything on.
Could this be a result of replacing hadlights with LED style bulbs?
Old Jan 15, 2025 | 02:43 PM
Camri's Avatar
It is possible that the headlight relays will click when the battery is reconnected, even with all the switches turned off. This may be due to a residual current or a slight activation of the relay. If this persists, check the connections and fuses. Have you noticed any other electrical problems ?
Old Jan 15, 2025 | 02:48 PM
billybob's Avatar
Default 67 rs relays
[QUOTE=Camri;749803]It is possible that the headlight relays will click when the battery is reconnected, even with all the switches turned off. This may be due to a residual current or a slight activation of the relay. If this persists, check the connections and fuses.
I found that relay 2 had the point stuck together
replaced new telay 2 with an old relay and all is working correctly
just have to adjust limit switches
thanks for the advice 👍
Big Ern
Jul 1, 2018 11:42 AM
Drewplmr
May 17, 2014 12:06 AM
freddybush
Feb 17, 2012 02:05 PM
ryan88z
Mar 9, 2009 09:01 PM
JDOBBS2
Oct 30, 2008 06:07 PM
