67 RS Headlight Assemblies
Old Feb 12, 2013 | 07:58 AM
Shark Bait's Avatar
Default 67 RS Headlight Assemblies
Hi Guys.
My sons 67 RS that we picked up from a field in Montana is coming along nicely.
Before
Now
Size:  173.6 KB Name:  B79A791D-F308-4E4D-AD9B-F495528E4889-205-0000001238B37CAB_zps30f14990.jpg
I have a couple of questions on the 1967 headlight assemblies
We have 2 new motors, limit switches and all the new bushings/washers in the housings. Also new wiring harnesses from American Autowire that includes the diode kit for the RS front headlights.
I only noticed 1 set of limit switches as we took the car apart. Now that I'm putting it back together I'm wondering how the limit in the open position is controlled? The limit switches we installed are on the bucket and closes as the headlight door hinge makes contact.
In the open position I don't recall any limit switch, is there supposed to be one?
The assemblies seem to move rather easily, there is not indication in any manual on how tight to make the nut on the motor shaft where the teflon washers, clamp washers and wave washer sandwich the motor arm. Should it move easily?
Thank you for the help.
Old Feb 12, 2013 | 08:09 AM
Shark Bait's Avatar
Looks like I just found my answer, looking at the AAW drawings I see connections for a limit switch on the radiator support. So I need to figure out where and how those mount.
hotrodz28454
Mar 23, 2010 03:13 AM
blink18236dude
Jul 10, 2007 10:53 AM
