67 rear brake lines
67 rear brake lines
I'm in the process of installing a 67 Camaro 8.2" 10-bolt rear axle under my 55 sedan. I've removed the stock spring perches and will be welding on a pair that fit my leaf springs.
Can someone please post a picture of how OE rear brake lines fit on the rear axle? And is there any reason I couldn't buy a set of pre-bent stainless lines from a vendor like Rick's Camaros (or a Camaro Forum sponsor)? I'll be using stock Camaro backing plates and drum brakes.
Thanks for your help.
Pre bent lines are available from any Camaro vendor. Installation is simple, the long line goes on the passenger side and the short line drivers. There should be tabs on top of the rear end to bend down over the lines that help hold them in place. Flex line block goes between the two hard lines ties it all together.
