67 Camaro Rim and tire size help
Hello, Almost finished my 67 Camaro and looking for the best rim sizes for front and rear. Plan on using Rally rims 15's. Has new front springs and shocks and new 5 leaf springs in rear w/12 bolt Posi..
Motor 327 525hp approx. 4spd
Have Disc on front and Drum on Back. Dont what to big in front or rear. Looking for suggestions...
Well you won't have to worry about going to big that's for sure. If you have a bascially stock set up. 15 x 7's in the front or you will rub on the tie rod and 15 x 8's in the rear is about all your gonna get.
525hp......impressive, better get some Cal-Trac bars or something similar and you might want to think about some sub-frame connectors. What series gears?
Thanks, 15x7 fronts and 15x8 Rear. Okay
The 327 is Bored 60, deck milled, Icon/Keith Black Domed Pistons 793 -62, Trick flow Aluminum Heads 23 deg 195 72 cc Cnc.. Hyd roller Cam 520-540 Original Forged Crank Manifluxed and cut 10/10. Eagle H beams. Engine completly balanced to included flywheel, piston wieght is 13.2 Oz, March Serp. Belt system Polished Alum Kit. Aluminum Rad. Made to handle 9500 Rpms..
This is the Original numbers macthing block 4spd m21,With a 69 Camaro 12 bolt Posi w 3:73 Gears. Car does have Custom maded frame connectors (My Design) They follow floor design without cutting floor. Car has had a complete frame off restoration. Just finished Painting Car with Dark Jade Metalic base/clear coat (Kirkers new Paint line) Kirker will be uploading Pic's Next week on ther site. I will Post pic's soon ..
Thanks again.
Thanks again.
