67 10-bolt rear "C" Clip removal
Old Feb 22, 2011 | 11:56 AM
ittybittyfds's Avatar
Default 67 10-bolt rear "C" Clip removal
hey everybody,
I am about to replace my rear drums with a Disc brake kit. In order to do this I need to remove the real axls so that the drum assembly can be removed. So if I understand correctly the way to do this is to remove the differential cover and pull out the 2 C clips that hold in the axls. Once removed the axls will easily come out and there is no need for a axl puller.
so my qestion is.... When I go to re install the axels should I re use the existing "C" clips or should I replace. Is there anything I should replace while I have the axls out?
Anybody who has done this brake swap find out that there is alot of extra $$$ associated with do the kit ?
Old Feb 22, 2011 | 12:37 PM
Remove the set bolt in the carrier and slide the spider gear cross shaft out, along with the gears. Don't mix up the spider gears, keep them marked top and bottom. Then you can push the axles all the way in, remove the c-clips, and slide the axles out. Installation is the reverse. Replacing the wheel bearings would be a smart idea. Replacing the c-clips isn't necessary, but if I had them out and in my hand, I would.
Old Feb 22, 2011 | 04:34 PM
tabascoboy's Avatar
There is a cool video on youtube. Just enter GM diff c-clip removal and you should see several videos. Have a magnet ready for the stuff that falls in the diff! Keep the shims with each of the spider gears as well. No big deal, just did it last weekend.
Tabascoboy
Old Feb 23, 2011 | 01:17 AM
juggernaut's Avatar
Wink
If you change the axle bearings, these make life easy.
TTMX511
Oct 6, 2013 08:35 PM
gfrench
Feb 26, 2011 11:21 AM
1995Camaro
Aug 9, 2010 06:15 PM
jason7504
Jun 24, 2009 03:55 PM
