454 is Alive !!
454 is Alive !!
Many winter projects - Comp cams LS6 nostalgia solid-lifer cam, performer RPM rect heads, airgap intake, quick fuel 830 carb, AC install, console-gauges-RS kit etc anyway finally the day for ignition and after a few glitches - dizzy one tooth off, pop and snort - started up and once timing and carb set smoothed out very well no huge leaks good oil pressure Alive.jpg?t=1304274123
