4 speed shifter
i have a hurst indy shifter and linkage on my 68 with a saginaw trans, and i have a stock camaro muncie shifter and linkage would it be possible to use the indy linkage with the muncie shifter and have it fit in the console ??
ur talking about the handle right? they should all interchange if the two bolt holes line at the bottom line up unless it the older style munice base.
Your Camaro muncie shifter should have the offset shifter handle for the console (so you can get it in reverse). Try this link to help you out.
Camaro - Transmission |
| All times are GMT -5. The time now is 09:54 AM. |
