4 speed noise
When I put the 4 speed in during the summer i hear a metal to metal noise only in reverse so am thinking it has to be the reverse gear what are your guys thought before I pull it out, thanks
It's going to be a whine as gear teeth are meshing.
If it sounds like somebody wading up foil, then yes, could be needle bearings shot or the bushing of the sliding idler gone.
As suggested, drain the oil and run a magnet through it.
[QUOTE=Edwardgp;656357]IMO I would drain her out and just take a look at the lube and probe with a magnet. Can't hurt anything. You will see whats going on in there.[/QUOT
i will try this when i pull the trans out thanks
grasshopper645
03-25-2013 02:42 PM
