396 normal operating temp
Hello, just got myself 68 camaro with 396 big block. took her for a short ride for the first time and saw the sunpro gauage showing temp in the middle between 210-280. pretty much stay the same going 10-20 mph in the first/second gear.
when i came home, i noticed a bit of condensation on the hood. when i open it, i noticed steam coming out of the opening from the radiator cap. From what I've read so far, the normal temp should be below 210...any opinions appreciated. |
stupid of me. radiator was pretty much empty.
Keep an eye on the coolant level to make sure you don't have any engine issues (intake gasket, head gasket, cracked head, cracked cylinder wall) that could have caused the radiator to be low.
(Post 628018)
Not sure why the radiator was pretty much empty. I enquired about it to the dealer. not sure if they flushed it and forgot or intentionally kept it low for delivery. |
"Keep an eye on the coolant level to make sure you don't have any engine issues (intake gasket, head gasket, cracked head, cracked cylinder wall) that could have caused the radiator to be low"
Or vice a vera, driving with little to no coolant could have cause those things. (surprised it didn't) |
Originally Posted by jno
(Post 628180)
If your temp gauge wasn't maxed out then your probably ok. Just something you have to do on these cars. I check my radiator and oil levels often. Although it shouldn't have been that empty, but who knows why it was so empty. When I bought mine last year I had to add a lot to the radiator, but I know the guy that owned it before me just drove it and I'm pretty sure he never did anything to it besides change the oil.
Something else to keep in mind, since you took 3 gallons of coolant, your whole cooling system (engine and radiator) was pretty much empty. This means the reading you were getting on the gauge was false (the probe reads coolant heat, not air heat), and your engine was most likely much hotter than you thought it was. Plus coolant in the water jackets dissipates heat away from the cylinder walls. That won't happen with the block being empty, let's hope you're ok.
I AM hoping it is ok. I could see some coolant at the bottom of the radiator. after putting in 3 gallons, I drove a couple of miles yesterday, and the temp stayed around 180 or so.
I was told all the fluids were changed. I should have checked at least the oil and radiator.. live and learn. Let's hope that the big block does not fail me... |
I always check all the fluids before taking a new car on the road, live and learn I guess. Now, if the radiator really was just changed and filled, you have issues. Don't wanna scare you, and hopefully it's for nothing, but just be cautious and watch the radiator level closely.
| All times are GMT -5. The time now is 09:14 AM. |
