1st Gen info that may be handy for a few people on here...
Hey there people... I found this info on the internets the other day and thought that few of us might find it handy...Check it out. It is the frame leveling and squaring info. Not sure if it is already posted here but here it is anyway!!!!!
Here is the cooresponding info for the pics...
Under Body Specs 67 thru 69 Camaro and Firebird Unibody Dimensions.
These measurements are modified from Fisher Body Specs, to correct printed errors in the Fisher Body manual. All measurements are center to center unless otherwise noted. Car must be setup on a level surface, for accurate measurements. A Tram Gauge is recommended for accurate results. Factory Tolerance plus or minus 1/8 inch. Note: Your car may measure out differently. This is due to difference in measuring methods used. Most important is that the car is square and level to its self. Be sure to read the Notes
Horizontal Dimensions:
A = 38 1/4"
B = 35 1/4"
C = 54 3/16"
D = 44 9/16"
E = 33 3/4"
F = 76" [/ul]
G = 65 1/4"
H = 33 1/2"
I = 55 3/16"
J = 66 11/16"
K = 43 7/8"
L = 44 7/8" [/ul]
Vertical Dimensions:
a = 11 15/16"
b = 12 9/16"
c = 13 13/16"
d = 9 1/8"
e = 6 15/16"
f = 18 7/16"
g = 15 11/16" [/ul]
Measurement Notes:
Center of Master Gauge hole outboard of firewall body mount
Center rear sub-frame to body mount hole
Center at rear edge of 1" gauge hole
Center of Master Gauge hole in bottom of frame rail
Inboard edge of frame rail, at centerline of rear shackle bolt hole (Figure 2)
Centerline of lower outboard bumper bolt holes [/ol]
Location f: Lower surface of rail at axle housing centerline
Location g: Inboard edge of frame rail, at centerline of rear shackle bolt hole (Figure 2) [/ol]
[IMG]local://upfiles/11028/539A3344204B48259A624BB048C63545.jpg[/IMG]
[IMG]local://upfiles/11028/8A90DA508A6F458CA62209CDF242C177.jpg[/IMG]
A = 38 1/4"
B = 35 1/4"
C = 54 3/16"
D = 44 9/16"
E = 33 3/4"
F = 76" [/ul]
G = 65 1/4"
H = 33 1/2"
I = 55 3/16"
J = 66 11/16"
K = 43 7/8"
L = 44 7/8" [/ul]
a = 11 15/16"
b = 12 9/16"
c = 13 13/16"
d = 9 1/8"
e = 6 15/16"
f = 18 7/16"
g = 15 11/16" [/ul]
Measurement Notes:
