1969 original tach needle
My needle keeps falling off.....don't want to use anything to adhere it back on without knowing how it's supposed to be held on....exactly how is it supposed to attach....simple friction fit?
Thanks...
Thanks...
Right, the needle should be a press fit onto the shaft. Does the needle go on slightly snug, but not tight, or is it way loose and it'll fall off if you look at it cross-eyed? If it just needs a tad more tightness, I'd give a little dab of loctite in the hole, and make sure you're pushing it on all the way.
PhilZulli
02-09-2011 03:41 PM
