1967 Camaro
Hi All,
I have a 1967 with a 12 bolt posi with 3.73 gears and a 350 (350hp) with a Turbo 350 with 2500 stall. I run at appr 3350 RPM on the highway at 65 and was looking at putting in a 700R OD tarnny. I talked to a rod shop owner builder and he said he would not make that change as he would go with a 3.08 instead. He also said I would be going down the highway at 65 MPH with RPM's only at 2200 RPM? That seems to go against all of the RPM calculators with that setup. I also have 26.1 tires. Anyone have any comment's on this?
Thanks
Thanks
If you go for the OD trans, THM200-4R would be my choice also, you may have to install a stock torque convertor as a looser one, higher stall rpm, would not be 'locked up,' thus heating up ATF more than it is designed.
I think what you are asking for is this. Since you are comparing RPM and speed on the same car with no other change other then the rear ratio we have everything we need. First we make a formula.
RPM / Rear ratio /(all other drive info)= 65 MPH
First we need to solve for (all other drive info)
3350/3.73/65=13.817
So now we can replace the rear ratio in our in our above formula
3350 RPMs / 3.08 /13.817= 78 MPH
2200 RPMs / 3.08 /13.817= 52 MPH
2766 RPMs / 3.08 /13.817= 65 MPH
You need to find another shop. This guy is clueless; forget he is poor with math. Who would recommend a cruising RPM below your stall point? Your car is going to feel like a dog with 3.08s in there. While everyone else in the free world is going to taller rears and over drives you are going to be cutting edge by going back to what the factory installed in 67?
3350/3.73/65=13.817
The TH350's case length is 21 5/8 inches. Depending on the tail shaft housing, its overall length can either be 27 5/8 or 30 5/8 inches. The 700R4's case length is 23 3/8 inches and its overall length is 30 3/8 inches.
Small block 67-8's are 49.96".
