replace/adjust 4th gen window motor/regulator
Old Sep 1, 2011 | 10:09 AM
Default replace/adjust 4th gen window motor/regulator
here are some directions from different sources. there is a link to this in the how to sticky at the top of the 4th gen section.
http://www.firebirdnation.com/pdf/windowreplacement.pdf
Power Window Motor
AutoTrix Install Instructions
Adjust Door Window
http://shbox.com/1/window_regulator2.wmv
Ls1/Lt1 Camaro Trans Am (Window Motor Install) - YouTube
Old Sep 1, 2011 | 10:23 AM
iLL95's Avatar
I Like to Party
Super Member
Haha that's the window motor vid I posted, is it being stickied?
Old Sep 1, 2011 | 10:25 AM
yes,,, like i said its in the how to sticky at the top of the 4th gen section. and thanks to all the guys who posted the links.
Old Sep 1, 2011 | 11:30 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I get to tackle putting window motors in both doors this weekend! The ones I got from ws6store didn't have the nut+bolt to replace the rivets. Does anyone know the size of them and the quantity I need so I can run to the hardware store? Thanks
Old Sep 1, 2011 | 11:31 AM
iLL95's Avatar
I Like to Party
Super Member
man i wish I could help you I forgot, ill do some research to help ya out
Old Sep 1, 2011 | 11:40 AM
iLL95's Avatar
I Like to Party
Super Member
1.Remove the door trim panel and inner panel water deflector.
2.Raise the window to half-up position and hold in place by inserting a rubber wedge door stops at the front and rear of the window between window and inner panel.
3.Remove the rear guide channel and inner panel cam channel.
4.Punch out the center pins of the regulator rivets; then drill out the rivets using a 1 / 4 in. (6mm) bit.
5.Move the regulator rearward and disconnect wire harness from the motor (if equipped). Disengage the roller on the regulator lift arm from glass sash channel.
6.Remove the regulator through the rear access hole.
If electric motor removal from the regulator is required, the sector gear must be locked in position. The regulator lift arm is under tension from the counterbalance spring and could cause personal injury if the sector gear is not locked in position.
7.Drill a hole through the regulator sector gear and backplate and install a bolt and nut to lock the sector gear in position.
8.Using a 3 / 16 in. (5mm) bit, drill out the motor attaching rivets and remove the motor from the regulator.
To install:
9.To install the motor to the regulator. Use a rivet tool, J-29022 or equivalent, and install 3 / 16 in. (5mm) rivets or 3 / 16 in. (5mm) nuts and bolts. Remove the bolt and nut used to secure the sector gear in position.
10.Place the regulator through the rear access hole into the door inner panel. If the electric regulator is being installed, engage the wire connector to motor prior to installing the regulator to the inner panel.
11.Locate the lift arm roller into the glass sash channel.
12.Using rivet tool J-29022 or equivalent, rivet the regulator to the inner panel of the door using 1 / 4 in. (6mm) 1 / 2 in. (13mm) aluminum peel type rivets (part No. 9436175 or equivalent). If the rivet tool is not available, use the following nut and bolt method:
A.Install U-clips on the regulator at the attaching locations. Be sure to install the clips with clinch nuts on the outboard side of the regulator.
B.Locate the regulator in the door inner panel. If the electric regulator is being installed, connect the wire connector to the regulator motor.
C.Locate the lift arm roller in the glass sash channel.
D.Align the regulator with clinch nuts to holes in the inner panel.
E.Attach the regulator (and motor) to the door inner panel with 1 / 4 -20 x 1 / 2 in. screws (part No. 9419723 or equivalent) into 1 / 4 in. (6mm) nuts with integral washers. Tighten the screw to 90-125 inch lbs. (10-14 Nm) torque.
13.Install the inner panel cam channel and rear guide channel.
14.Remove the rubber wedge door stops at the front and rear of the window between window and inner panel.
15.Install the inner panel water deflector and the door trim panel.
Old Sep 1, 2011 | 11:44 AM
thanks
Old Sep 1, 2011 | 11:48 AM
iLL95's Avatar
I Like to Party
Super Member
No problem
Slick6
Nov 1, 2011 10:54 PM
jd0624
Sep 6, 2010 11:10 AM
MartineZ28
Jun 18, 2010 10:12 PM
Fortee
Apr 6, 2008 05:13 PM
z28pete
Aug 4, 2006 11:04 PM
