-   2016 Discussion (https://camaroforums.com/forum/2016-discussion-145/)
-   -   Best Audio System in a Callaway Camaro ZL1???? *Build Log Inside* (https://camaroforums.com/forum/2016-discussion-145/best-audio-system-callaway-camaro-zl1-%2Abuild-log-inside%2A-82326/)
musaic_design Mar 11, 2018 09:34 PM
This job was a massive undertaking. A complete Musaic Audiophile Conversion combined with our custom Radar and Laser Integration. We engineered our equipment to blend into the factory DNA of the vehicles OEM design.
Starting with the audio, we completely gutted the interior and sound dampin the car with Soundskins Pro. This ensures that we will have a much quieter environment to enjoy the subtle nuances of our audio system. The front stage consists of a Focal Utopia No.7 3 way speaker set run fully active. We used a simple set of Focal Integration speakers to replace the rear speakers. The OEM interior plastic panels were also treated with Soundskins Pro to eliminate any potential panel rattle. The inner doors were treated with Blackhole Tile to greatly reduce the back wave reflection from the door speakers. Hand fabricated PVC speaker adapters were made to mount our Focal drivers right to the existing bolt holes of the OEM door skin.
A Nav-TV M650-GM interface was used to take the OEM audio signal, ensuring we have a clean, unclipped, full range signal directly to our Mosconi 8to12 Aerospace DSP. An AMAS2 was added to connect our HI-Res Fiio DAP to a separate preset giving us a clean digital source directly into our processor. That signal then fed into three Mosconi ZERO amplifiers. A Mosconi ZERO1 powered two Focal Utopia 21wx Subwoofers and two Mosconi Zero4's were used to run our front 3 way Focal Utopia and rear coax fully active. The mid and tweeter of the Focal Utopia No.7 Kit was housed in a hand fabricated custom A-Pillar which was wrapped with an exact match OEM vinyl.
A new Stinger AGM battery was used to replace the OEM battery and a AGM trickle charger was permanently installed next to it. A flush mount marine 120v plug was mounted under the car for an easy, hassle free, charging solution. A Stinger 10 Farad Cap was added to dampin the high voltage spikes of the factory alternator.
The subwoofers were housed in a baltic birch subwoofer enclosure with an acrylic window, which gives you sight to view the beautiful magnets. The rear of the enclosure can be viewed if you pull down the rear seat.
The amp rack was completely fabricated using multiple layers of acrylic and PVC. We made mostly everything by creating organic shapes using multiple router techniques and heat to bend and manipulate the materials. The materials used in the trunk were to bring focus onto what was used in the interior. Black Alcantara suede, brushed aluminum, matte black, matching black vinyl, and red and white accent lighting were used to layer the trunk. All panels are securely mounted used 1/4-20 Stainless hardware. Everything can be removed and put into the very same position as if the panels were OEM.
For the Radar and Laser we used a K40 Electronics RL360i Expert utilizing a front and rear radar sensor and 4 separate laser diffusers. The front laser diffusers were fabricated to ghost into the front bumper openings. Molex plugs were used to terminate each harness going to the front and rear bumper for OEM like servicing. A static touch maser power kill switch was mounted behind the suede panel to the right of the factory radio over the Callaway emblem. Hit this once with your finger and you can easily kill power to the entire radar and laser system.
https://scontent-lga3-1.xx.fbcdn.net...ca&oe=5B392C55
https://scontent-lga3-1.xx.fbcdn.net...7f&oe=5B090353
https://scontent-lga3-1.xx.fbcdn.net...f8&oe=5B051B6A
https://scontent-lga3-1.xx.fbcdn.net...0c&oe=5B021A56
https://scontent-lga3-1.xx.fbcdn.net...af&oe=5B07CD83
https://scontent-lga3-1.xx.fbcdn.net...a4&oe=5B47FE4B
https://scontent-lga3-1.xx.fbcdn.net...9e&oe=5B485EC7
https://scontent-lga3-1.xx.fbcdn.net...89&oe=5B4C8CE5
https://scontent-lga3-1.xx.fbcdn.net...47&oe=5B499912
https://scontent-lga3-1.xx.fbcdn.net...5c&oe=5B01EF61
https://scontent-lga3-1.xx.fbcdn.net...aa&oe=5B04B038
https://scontent-lga3-1.xx.fbcdn.net...32&oe=5B023006
https://scontent-lga3-1.xx.fbcdn.net...ef&oe=5B45A1E9
https://scontent-lga3-1.xx.fbcdn.net...0b&oe=5B035A2A
https://scontent-lga3-1.xx.fbcdn.net...23&oe=5B3FF5E7
https://scontent-lga3-1.xx.fbcdn.net...5c&oe=5B0739BE
https://scontent-lga3-1.xx.fbcdn.net...36&oe=5B44550D
https://scontent-lga3-1.xx.fbcdn.net...92&oe=5B41CE9E
https://scontent-lga3-1.xx.fbcdn.net...cb&oe=5B40EE8B
https://scontent-lga3-1.xx.fbcdn.net...a7&oe=5B46E550
musaic_design Mar 11, 2018 09:37 PM
https://scontent-lga3-1.xx.fbcdn.net...b0&oe=5B03963F
https://scontent-lga3-1.xx.fbcdn.net...5a&oe=5B3A5B7B
https://scontent-lga3-1.xx.fbcdn.net...95&oe=5B3AA89A
https://scontent-lga3-1.xx.fbcdn.net...3e&oe=5B049BEE
https://scontent-lga3-1.xx.fbcdn.net...ee&oe=5B3A6533
https://scontent-lga3-1.xx.fbcdn.net...b6&oe=5B3BA083
https://scontent-lga3-1.xx.fbcdn.net...dd&oe=5B39E2D8
https://scontent-lga3-1.xx.fbcdn.net...33&oe=5AFFC3B7
https://scontent-lga3-1.xx.fbcdn.net...39&oe=5B479EDB
https://scontent-lga3-1.xx.fbcdn.net...a2&oe=5B067D23
https://scontent-lga3-1.xx.fbcdn.net...18&oe=5B071071
https://scontent-lga3-1.xx.fbcdn.net...f2&oe=5B497BA5
https://scontent-lga3-1.xx.fbcdn.net...b6&oe=5B367C29
https://scontent-lga3-1.xx.fbcdn.net...bb&oe=5B068B72
https://scontent-lga3-1.xx.fbcdn.net...f0&oe=5B4C5FD9
https://scontent-lga3-1.xx.fbcdn.net...59&oe=5B4BE4AE
https://scontent-lga3-1.xx.fbcdn.net...22&oe=5B336DAD
https://scontent-lga3-1.xx.fbcdn.net...a4&oe=5B364B0C
https://scontent-lga3-1.xx.fbcdn.net...f0&oe=5B44B8FC
https://scontent-lga3-1.xx.fbcdn.net...92&oe=5B3CCB02
https://scontent-lga3-1.xx.fbcdn.net...14&oe=5B425F73
https://scontent-lga3-1.xx.fbcdn.net...ac&oe=5B3ABA8A
https://scontent-lga3-1.xx.fbcdn.net...0a&oe=5B345C05
https://scontent-lga3-1.xx.fbcdn.net...b9&oe=5B48972A
https://scontent-lga3-1.xx.fbcdn.net...28&oe=5B4E4C42
https://scontent-lga3-1.xx.fbcdn.net...27&oe=5B4642E6
https://scontent-lga3-1.xx.fbcdn.net...3b&oe=5B4774C8
https://scontent-lga3-1.xx.fbcdn.net...ad&oe=5B4656E3
https://scontent-lga3-1.xx.fbcdn.net...c5&oe=5B03D2D9
https://scontent-lga3-1.xx.fbcdn.net...0e&oe=5B42BF99
https://scontent-lga3-1.xx.fbcdn.net...5e&oe=5B38996D
https://scontent-lga3-1.xx.fbcdn.net...ed&oe=5B35B214
https://scontent-lga3-1.xx.fbcdn.net...39&oe=5B3A4A51
https://scontent-lga3-1.xx.fbcdn.net...57&oe=5B46BEEC
https://scontent-lga3-1.xx.fbcdn.net...c0&oe=5B3B32BC
https://scontent-lga3-1.xx.fbcdn.net...9b&oe=5B45AF8C
https://scontent-lga3-1.xx.fbcdn.net...08&oe=5B3EF234
https://scontent-lga3-1.xx.fbcdn.net...ac&oe=5B457A14
https://scontent-lga3-1.xx.fbcdn.net...31&oe=5B36B694
https://scontent-lga3-1.xx.fbcdn.net...7a&oe=5B4A7806
musaic_design Mar 11, 2018 09:38 PM
https://scontent-lga3-1.xx.fbcdn.net...80&oe=5B465F65
https://scontent-lga3-1.xx.fbcdn.net...e9&oe=5B35BFA7
https://scontent-lga3-1.xx.fbcdn.net...c9&oe=5B345B95
https://scontent-lga3-1.xx.fbcdn.net...39&oe=5B04480D
https://scontent-lga3-1.xx.fbcdn.net...34&oe=5B4274B6
https://scontent-lga3-1.xx.fbcdn.net...dd&oe=5B4178D8
https://scontent-lga3-1.xx.fbcdn.net...97&oe=5B062879
https://scontent-lga3-1.xx.fbcdn.net...51&oe=5B4AE537
https://scontent-lga3-1.xx.fbcdn.net...2c&oe=5B48405B
https://scontent-lga3-1.xx.fbcdn.net...87&oe=5B01494F
https://scontent-lga3-1.xx.fbcdn.net...97&oe=5B468EB1
https://scontent-lga3-1.xx.fbcdn.net...96&oe=5B452906
https://scontent-lga3-1.xx.fbcdn.net...fe&oe=5B40C005
https://scontent-lga3-1.xx.fbcdn.net...2c&oe=5B37A46F
https://scontent-lga3-1.xx.fbcdn.net...26&oe=5B4E63DD
https://scontent-lga3-1.xx.fbcdn.net...cf&oe=5B41DFF4
https://scontent-lga3-1.xx.fbcdn.net...04&oe=5B074D53
https://scontent-lga3-1.xx.fbcdn.net...1c&oe=5B43057B
https://scontent-lga3-1.xx.fbcdn.net...1b&oe=5B328229
https://scontent-lga3-1.xx.fbcdn.net...de&oe=5B4BB52B
https://scontent-lga3-1.xx.fbcdn.net...5a&oe=5B34925A
https://scontent-lga3-1.xx.fbcdn.net...4a&oe=5B4267BF
https://scontent-lga3-1.xx.fbcdn.net...84&oe=5B374B69
https://scontent-lga3-1.xx.fbcdn.net...45&oe=5B4CAFEC
https://scontent-lga3-1.xx.fbcdn.net...91&oe=5B4E1778
https://scontent-lga3-1.xx.fbcdn.net...23&oe=5B4344FE
https://scontent-lga3-1.xx.fbcdn.net...a8&oe=5B3686CA
https://scontent-lga3-1.xx.fbcdn.net...58&oe=5B4C14A0
https://scontent-lga3-1.xx.fbcdn.net...f2&oe=5B46C98F
https://scontent-lga3-1.xx.fbcdn.net...0b&oe=5B04538D
https://scontent-lga3-1.xx.fbcdn.net...c9&oe=5B32DEA8
https://scontent-lga3-1.xx.fbcdn.net...fb&oe=5B3EC083
https://scontent-lga3-1.xx.fbcdn.net...d6&oe=5B4E643F
https://scontent-lga3-1.xx.fbcdn.net...f0&oe=5B39A38E
https://scontent-lga3-1.xx.fbcdn.net...7e&oe=5B33C376
https://scontent-lga3-1.xx.fbcdn.net...ee&oe=5B4E16C6
https://scontent-lga3-1.xx.fbcdn.net...10&oe=5B3C744D
https://scontent-lga3-1.xx.fbcdn.net...5c&oe=5B0784B2
https://scontent-lga3-1.xx.fbcdn.net...40&oe=5B44F147
https://scontent-lga3-1.xx.fbcdn.net...ed&oe=5B056038
musaic_design Mar 11, 2018 09:39 PM
https://scontent-lga3-1.xx.fbcdn.net...de&oe=5B4B3612
https://scontent-lga3-1.xx.fbcdn.net...a4&oe=5B359723
https://scontent-lga3-1.xx.fbcdn.net...b1&oe=5B3EC624
https://scontent-lga3-1.xx.fbcdn.net...3a&oe=5B49E2B6
https://scontent-lga3-1.xx.fbcdn.net...c9&oe=5B4890A8
https://scontent-lga3-1.xx.fbcdn.net...05&oe=5B03F6AE
musaic_design Mar 11, 2018 09:40 PM
https://scontent-lga3-1.xx.fbcdn.net...b5&oe=5B06C7CE
https://scontent-lga3-1.xx.fbcdn.net...5c&oe=5B4BB0E1
https://scontent-lga3-1.xx.fbcdn.net...44&oe=5B4245C9
https://scontent-lga3-1.xx.fbcdn.net...bc&oe=5B32C87E
https://scontent-lga3-1.xx.fbcdn.net...93&oe=5B3B2BDF
https://scontent-lga3-1.xx.fbcdn.net...9b&oe=5B3C46DB
https://scontent-lga3-1.xx.fbcdn.net...73&oe=5B3FA445
https://scontent-lga3-1.xx.fbcdn.net...41&oe=5B359E41
https://scontent-lga3-1.xx.fbcdn.net...da&oe=5B40A66D
https://scontent-lga3-1.xx.fbcdn.net...ef&oe=5AFFC3A4
https://scontent-lga3-1.xx.fbcdn.net...d2&oe=5B06BD9A
https://scontent-lga3-1.xx.fbcdn.net...0f&oe=5B331C5D
https://scontent-lga3-1.xx.fbcdn.net...90&oe=5B40307C
https://scontent-lga3-1.xx.fbcdn.net...41&oe=5B03CD03
https://scontent-lga3-1.xx.fbcdn.net...93&oe=5B4AC6FB
https://scontent-lga3-1.xx.fbcdn.net...93&oe=5B45A918
https://scontent-lga3-1.xx.fbcdn.net...e3&oe=5B3EE584
https://scontent-lga3-1.xx.fbcdn.net...b2&oe=5B49210B
https://scontent-lga3-1.xx.fbcdn.net...de&oe=5B4841D9
https://scontent-lga3-1.xx.fbcdn.net...b6&oe=5B0760E6
