Wheel adapter possible?
Hey everyone, I'm new here. I'm Bas Jussen, 38 yrs, law clerk from the island of Curacao. I'm planning on buying a 5th gen Camaro V6 (2010 or 2011) in Florida and import it to the island soon. I would like to put my 20" rims on it that I already have from another car. Unfortunately they have a different offset and lug pattern, so I wonder if I could use wheeladapters (from wheeladapters.com), without the tires rubbing or wheels sticking out of the fenders (and without compromising the ride of course).
The wheels are Showwheels Streeter 20x8.5 (both front and rear!) with a +12 offset and 5x4.5 lug pattern (I used them on a Ford Sport Trac). I believe the 2010/2011 Camaro has an offset range 35-45 (high positive offset) and a 5x120 bolt pattern, if I'm correct.... Hope someone can help out. Best regards, Bas Best regards, Bas |
uhhh maybe yes the wheel adapters will let you bolt on the wheel but they will be stcking out 5-6 inches and you will most likely see an interfeerance when you attemp to turn being that far out but pictures of the current wheel you have would be helpful
