Traction control correction
Old 11-18-2017, 11:57 AM
HWoods57's Avatar
Default Traction control correction
Does anyone know how to bypass or recalibrate the traction control so that you can run different outside diameter tires or know the proper ratio that needs to be maintained?
Old 01-27-2018, 06:31 PM
Rombama's Avatar
yes, you need to find a shop that has a programmer or buy your own programmer. it's usually cheaper to have a shop do it, they'll charge about $180 but that's cheaper that buying the programmer, they run $400-$500 usually. Unless you plan on doing a lot of stuff, then buying the programmer might be the better option.
Old 01-27-2018, 08:07 PM
HWoods57's Avatar
Thanks for the reply
i actually went to a few shops and ended up at a Chevy performance shop to learn that there is no resetting or recalibration just disabled.
Ended up requiring adjustment to match outer wheel diameters
OTDetailer
07-13-2012 11:00 PM
OTDetailer
07-03-2012 11:29 AM
OTDetailer
05-24-2012 03:26 PM
Combat_Chuck
04-19-2008 11:03 AM
codyhcahoon
05-09-2006 09:37 PM
Quick Reply: Traction control correction
