Tire pressure sensor malfunction
i have a 2011 Camero SS and after a few minutes of driving my "low tire pressure sensor" goes off for my front right front wheel where my electronic driving speed shows up on my dash. I have checked the tire pressure for all of my tires several times with different electronic gauges for verification. All of them read 37 PSI. Has anyone else had a problem with this sensor? Any ideas why this is going off every time I drive?
I have a 2010 SS with the same recurrent sensor problem....I am planning on replacing all sensors and start from scratch.....will keep you informed
The sensors have an internal battery in them which operate when the wheel is in motion. The battery's are good for about 7 years or so. Replacing the wheel sensors in the wheels should cure the issue. In addition after the new tire Sensor are installed they will need to be programmed with the old sensors code so the car will recognize them.
Worked for me ! |
